I’m a newbie with SketchUp (SU) and am stuck on a procedure; I wonder if you might be able to help me.
Let’s say I’m making a simple mortise and tenon joint. I’ll be using a 1″x6″x3′ stretcher with a tenon on the end, maybe 3/4″ wide by 5″ tall.
I want that tenon to go into a mortise on a leg, 4″x4″x 36″….so that it is centered on the leg, and the stretcher’s top is flush with the top of the leg – a usual scenario.
I understand how to create the stretcher and tenon, as well as the leg, and can position the tenon and stretcher just where I want it – at the top of the leg – and have the tenon inside the leg.
So far, so good!
What I would like SU to do for me is to create the mortise for me, so that if I should “explode” the drawing, I would see a cut-out mortise in the leg. This would also be great for dovetails, lap joints, and so on.
I would really appreciate any help you could offer!
Patrick, did you get my e-mail response to your question?
Dave
Thank you for your reply!Just before I got it, I was still trying to figure a way to do it, and was able to! Take a look at the movie I made....http://thirddayproductions.com/mortise2.mov
pashley-
I'm sure Dave's Email contains a better explanation, but I will attach mine if others are interested. Click on Home to start.
Don
Edited 3/28/2008 2:24 pm ET by DonaldCBrown
