Working with Sketchup, I often find it necessary to rotate a wood grain texture, for example on a coped door frame or face frame.
The Select/texture/position/rotate sequence does the job. Sometimes there are numberous faces to rotate. Is there anyway to automate or repeat this process via a macro type command?
Thanks.
No, there isn't but there are a couple of alternatives. One is to sample the roated texture with the eyedropper. After you've sampled the rotated material, the tool reverts to the paint bucket. Then you can apply that material to the next face.
The other option is to export the material JPG and rotate it in your favorite image editor. Then save it so that you have both vertical and horizontal versions. Then import the rotated material and save it to the Wood library.
Dave
