I have been asked to build a large dining table,46″ x 120″, with a thick top. The base is to be painted black and the top finished natural with tung oil. The trestle base is no problem, but she wants a slab top of cypress, about 2 1/2″ thick. In my area there is no such thing as kiln dried stock 2 1/2″ thick. I can get the cypress as air dried but then it is about 15% MC. I can easily install the top to float and take care of the shrinkage by locating it with 2 pins in the middle and let gravity hold it down, by my math the top will weigh about 250 pounds. But I am concerned about controlling cupping. have any of you dealt with this problem?
Instead of just relying on gravity, you can pull the top down to the trestle rail, with slotted holes for the screws. I believe Lee Valley has washers with slots that could make it easier for the screw heads to slide as needed.
I think you are also helped by the fact that cypress is a relative stable wood.
