I have a job that in one area the customer wants the cabinet doors to slide. So they would be by-pass doors. This is in a laundry room over the machines. She does not want to hit her head on the open doors.
So any thoughts as to where I could look for this type of hardware?
http://www.rockler.com/product.cfm?page=10878
You can make your own track out of hardwood. Don't forget that the top groove needs to be deeper than the bottom so you can insert the doors.
John White
Shop Manager for FWW Magazine, 1998-2007
Funny you should ask, 'cause I just finished a TV cabinet with sliding doors for a customer, and am making a wall bookcase unit that has more.
I just made the tracks from hardwood and cut rabbets on the doors to fit in the tracks. Piece of cake after you figure it out. - lol
Here are some pics and I can get some more if you'll tell me what you want to see.
Great piece! Do you have anything to help with the friction of wood on wood? curiousThe nine most terrifying words in the English language are, 'I'm from the government and I'm here to help.' - Renaldus Magnus
I did something similar for some upper kitchen cabinets. I just made a pair of grooves out of a single piece of cherry about 3/4 x 2/1/4, each groove just a little bit (1/16" or so) wider than the doors. I put a piece of UHMW tape in the bottom of the groove and the doors move easily.
Just make the top grooves (dadoes?) deep enough that you can put the door in and have it drop down but not fall out.
If I get a chance, I'll find a picture.
I make the track grooves ~1/16" wider than the "runners" on the doors and that seems to work just fine. I also tell customers that rubbing a little candle wax on the door runners usually frees up any binding that may occur.
I did a set for a bathroom using the nylon wheels for a screen door. They are turn on a maple dowel and are set into the bottom of the door. Hardware for this application is also sold by Richelieu Hardware. This being said, I'll not do it this way again. Running hardwood on hardwood is the best. A little wax and you will never touch them again. The windows I made for my basement slide on a maple tongue.
http://www.johnsonhardware.com/
Your local Home Depot, Lowes, hardware store should have something.
http://www.epcohardware.com
Here'a photo of the slides I made on the table saw, using the dado blades.
I see no one has suggested attaching magnetic strips to the runners of the doors, and then using a series of electromagnets in the cabinet frame to levitate the doors. With the right circuitry, one could even open and close the doors with a remote control! ;-)
