I have a sliding door I would like to seal it up. At the bottom and on the sides. And I know I should have stayed away from the sliding doors. But I like them, for bringing big pieces into my shop. My door is about 8 feet tall and about 10′ feet wide. I have tried pressure treated wood at the bottom. Where the door meets the floor. But it looked to funky so I took it out. I live in Calif. So it is not to bad right now. But I would like to seal it up before winter. The door is mounted on the outside. And I love the door it is made out of cedar. Any suggestions. Thanks Hat
I don't have a sliding door, so I may be talking through my hat here. But, it seems to me that the best approach would be a combination of inside and outside weatherstripping - outside for normal and wind-driven rain, and inside for major drafts. Depending on the construction of the door, you might need to use weatherstripping panels (long boards with the weatherstripping attached) that are moved or flipped into position once the door is closed. Larger versions of "draft tubes" (filled fabric tubes that are placed against drafty cracks in the door opening) might also help, perhaps using Velco to keep them in place.
If it is nicely fit, look at a good patio door and mimic it. At the other end of the spectrum is brush stripping used on industrial doors. Standard source is McMaster-Carr. Have two on a barn workshop, both top hung. On one, I ran wide foam weather-stripping around the outside of the opening and then used pull latches to pull the door tight to the weather-stripping. Doesn’t get used much and was easy. On the second, I used brush stripping. Allowed me to deal with the imperfections of an 80 year old concrete foundation.
dloc & hat,
A source for the brush sealers: http://www.memtechbrush.com/productinfo.htm
The sides should be easy with conventional, store-bought material.
How about a water-filled tube for the bottom?
Frosty
