Hi folks I am looking for something that I just can not find.
I am working on my kitchen (not bad 3 years and counting now) and I want to install some upper cabinets over the bar area of my kitchen. The kitchen/bar area has a modern look and as such i am going with a modern look on the upper cabinets
What I would like to do is put a solid glass back on the cabinet and do a solid glass (double) door on the front. Either a slider (bypass) door set up or a hinged door set up. (but something nicer then the standard hardware they use to make entertainment centers).
So does anyone know of a system that does glass (framless for the most part) do do a slider or a swing door? I have not been able to find anything.
Doug M
Try this site: http://www.allglassparts.com/catalog/400217/
Turned it up on Google looking for "glass showcase hardware". There are probably others.
Shop Manager for FWW Magazine, 1998 to 2007
John thanks for the link I will try it I will also try the search you suggested. Tried glass doors and sliding glass door and all you get are patio doors! Ugh.
Doug M
Patio doors were the first things I came up with also. Often times the biggest problem with an online search is finding a search term that eliminates the junk. Glad I could help. Another resource is a good local glass shop.John White
Yeah I think I will have to go and talk to my glass shop. I found a few things online after your suggestion but it is hard to figure out what I want with out more touchy feely. The web pages i was on for the most part do not do a good job of showing you what you get.
Doug M
try c.r. laurence
http://www.crlaurence.com/crlapps/showline/offerpage.aspx?Productid=38376&GroupID=27575&History=39327:9307:19712:23605&ModelID=27575
may be the product you are looking for.
but you can search their website.
If they ain't got it, it's gonna be really hard to find
But they are protective of their distributors, so you may have to order it through a local glass company. .
Eric
