I`m looking for a sliding cut off table that mounts to a 36-844 left tilt unisaw without touching the floor , I don`t think the delta one will fit because the motor cover sticks out. I see the accusquare M1, are there anymore, how about Canadian suppliers?
Johnny
What size slider, for panels or a small unit like the Dewalt? Laguna sells a bolt on table but I'm not sure if it works on a left tilt when mounted on the right side. You do want to mount it on the right, correct? I have seen a couple of Dewalt tables mounted on the left of Unisaws and a PM66. Why they mounted it on the left on a left tilt saw is beond me, but what do I know. I use an Exactor on a right tilt Unisaw. This hints of the right tilt left tilt debate. I have said many times if you buy a left tilt saw and want to add a sliding table the table should be mounted on the right side. If mounted on the left of a left tilt, saw you defeat the purpose of the left tilt when bevel cross cutting.
Dave Koury
I saw the Exactor at a show last Nov., and liked it, and the owner of the company. How do you like the Exactor? Accurate? Do you have to fiddle with it often to retain alignment? Thanks for the info.
Alan
