I’ve used drum sanders before, and there are certain times when having one would be really handy. However, I think 95% of the stuff I would use it for would only be 8″ wide or less, like laminated strips for a bent table apron, 1/8″ square inlays, etc. Plus, shop space is always an issue.
I just don’t need or want a big 16″ drum sander. I’ve looked, but I’ve never seen a 8″ or even 6″ wide drum sander. It would be a great help to me. Anyone seen or have one?
Kevin
I haven't seen any commercially available drum sanders that small, but I have seen plans for a homemade one. They are in a book called "Luthiere Tools",
and I think it's published by the Guild of American Luthiers. You could check their website for availability.
That drum sander was made with a 6" long sleevless sanding drum attached to a motor,with an adjustable table below it. It wasn't very complicated, and it probably wouldn't take much to make one like it.
Hope this helps.
Rick W.
Look or call Klingspor,
They have a small Performax sander.
Also a kit, which might be modified smaller.
Here are some pics that Mike sent me back a while ago when I was looking at building a thickness sander. Mike posts here under PlaneWood but I don't think he has been around much do to some other matters.
Scott C. Frankland
"This all could have been prevented if their parents had just used birth control"
Hello,
Penn State has come out with a smaller drum sander. It is not a precise thickness sander, just a drum sander. Take a look at their website.
Chuck
Here's a link to the Klingspor kit Jeff in Vermont mentioned http://www.woodworkingshop.com/cgi-bin/E2767C80/mac/additmdtl.mac/showItemDetail?item=PS35000&qtyA=0&phsO=N&desc=18%22%20PORTABLE%20SANDING%20DRUM%20KIT%20*&drpshp=N&alOrd=Y&iQty=.000&oQty=.000&initQty=1&itemForSale=Y&styleName=&fixD=&face=.00&gftc=&stck=Y&prefS=UP4&calledFrom=DS&ordInfo1=&ordInfo2=&ordInfo3=&ordMan1=N&ordMan2=N&ordMan3=N&persCode=&persReqd=&persLink= Saw it demonstrated at a woodworking show and it seemed to work pretty well. Might be what your looking for.
