I use some small drum sanders, 1″ and 2″, getting the old sleeve off is no problem- but getting the new one on is like potting a square peg in a round hole. The new sleeves are so tight that I can only get it 2/3’s of the way on.
Any tips on installing new sleeves on these drum sanders?
Put the rubber drum in a freezer for a coupla hours.This will contract it enough to remove the paper, or replace the paper.
Thank you for your help. I'll try the freezer next time.
About once every six months I read a post that actually has a usefull piece of information. Thanks
Thank you for your kind words.Expansion and contraction are often overlooked issues in machinery and woodworking,but it's an important consideration.
I find that dusting the drum and sleeve with talcum, intended for the babys bottom,is a big help in this situation.
Work safely ¬¬¬¬¬¬¬¬¬¬PAT¬¬¬¬¬¬¬¬
