Hi Folks!
I’m looking for recommendations for a small electric/battery powered buffer (emphasis on small) that I can buy to help apply cutting board wax to the boards that I make. Every search I’ve done has lead me to the typical answers of large buffers that are primarily good to use on tables, or simply adding buffing pads to my R/O sander or angle grinder but I’m looking for something specifically for small items that is easy to maneuver, maybe in the 3-4″ diameter range.
The closest thing size wise to what I’m looking for is the Dremel Versa, which is small and has a buffing attachment, but the reviews I’ve read haven’t been very strong.
If anyone has any insight on how the Dremel Versa performs for buffing, or a suggestion of another tool I’d love to hear it.
Thanks!
Joe,
Two Penny Custom
This Milwaukee should do the job.
https://www.milwaukeetool.com/Products/Power-Tools/Metalworking/Sanders-and-Polishers/2438-22X
I don't understand why a buffer pad on a 5" orbital sander wont work except for the usual lack of power for buffing. I googled your work and see what you are making. If you are in business and trying to make work efficiently I would try the sander buffer again.
Another option is a small cordless right angle drill with a 3 inch Velcro pad like the lathe guys use. It would at least be a real tool with power. I wouldn't count on anything from Dremel being worth the money especially for a business enterprise like yours. Check this out below.
https://www.cpopowertools.com/right-angle-drills
I'm guessing he's looking for something he can use one handed while holding the cutting board in the other. I can see the value in that especially when buffing edges and not worrying about the buffer throwing the piece across the room.
Have a look at the DA (dual action) polishers, which are used for cars. These come in 3", 5" and 6" sizes. Each also has a different throw. The 3" with a 10cm throw is probably all you will need. Plus you can polish your car with it :) Look at the different pads available. These provide a lighter to heavier action.
