In case some of you don’t go to other forums I thought I’d post this here also. I bought a small perfect handle screwdriver at an antique store for 50 cents and decided to totally redo it. I replaced the old unknown hardwood scales with boxwood and left out the rivets because I figured that the epoxy will hold it just fine. I bought another screwdriver today that is slightly larger and it seems that these screwdrivers are labeled with their size. Under the scales of the small one it has the number 100 cast into it and under the scales of the slightly larger one it has the number 175 cast into it. Anybody know anything about this? Well anyways here are the pictures. The first is before and the second is after
http://i179.photobucket.com/albums/w289/Ryan-Cathey/Haul/100_0280.jpg
http://i179.photobucket.com/albums/w289/Ryan-Cathey/100_0286.jpg
It looks like you did good work. I can't help you with the casting number on the screw driver. If you find out then post it. I would be interested.
Thanks. The boxwood looks like bone or ivory in real life. Yeah, I'll do that if I find out.
