Does anyone have a mail order source for brass rods and brass plates or bars.
Thanks in advance
Bob
Thanks in advance
Bob
I've not bought brass from them, but I've bought other things and found them very easy to work with: McMaster-Carr. Just a quick look, seems they sell nine different brass alloys, in sheets, bars, strips, foil, rods, hex bars, tubes, u-channels, 90° angles, balls, wire and ingots. They sell with the following finishes: unpolished, brushed, mirror-like, reflective, and ground.
No affiliation, just a satisfied customer who has felt pretty good to find some pretty obscure stuff there.
http://www.alaskancopper.com
Thanks for the information. Great sources.
Bob
Check out the "Yarde drop zone" on line, great deals in all kind of metals.
C.
Sorry to hijack the discussion, but does anyone know if you can solder a wire to a brass plate? I want to use a brass plate connected to a touchswitch on a lamp I'm building.
Very easy, both copper wire and brass solder easily. If the brass piece is much larger than a dime you will probably need to use a torch rather than an electrical soldering iron to get the brass part hot enough. Clean the parts well, Scotchbrite is a good abrasive, and then use a rosin cored electronic solder to make the join.
John W.
Excellent. Thanks for the reply! Will the heating affect the color of the brass?
I'm thinking of a brass plate about 1" x 3". Does anyone know where to get something like this in small quantities?
Thats a common size for trophys and award plaques. I would think a trophy supply or an engraver could fix you up.
Since the house is on fire let us warm ourselves. ~Italian Proverb
If you don't heat the piece too far beyond the point of melting the solder you shouldn't permanently discolor the brass. Any mild discoloring is on the surface only and will buff out with Scotchbrite or steel wool. To keep the brass shiny it will have to be lacquered. You can get metal lacquer in spray cans at most hardware stores.
If you have a hobby shop nearby check with them for brass, they often stock sheet brass in a 3"x5" or 4"x6" size. It may be more expensive per square inch than ordering it on line, but it will be cheaper overall because of the smaller size and no shipping charges.
I used a brass kick plate off an old door and cut it into strips for name plates; brass is soft and cuts easily.
Pasa bon tarde.
Thanks to all for the suggestions and information about brass. I'll check out a local trophy shop and see if I can get some plates there cheaply.
I've ordered a few things from this place before and been happy with their service
http://www.onlinemetals.com
If you build it he will come.
