All,
About 6 months ago I was given some SA cherry..3 boards 8″x80″. After cleaning them up they are about 5/8″ thickness with a very nice grain…which really looks teriffic with just a little BLO. It is very dense stuff. Using a smoothing plane on the wood was like planing leather…the wood just ripped….and I’m kinda concerned that dovetails and the like just wouldn’t work very well.
I’m looking for a project…that is appropriate for this kinda wood. Is it only used as accent wood? I’d love to make a little table…but the stock is kinda thin. What is your experience and recommendation?
I also have 4 – 2 1/2x2x40″ sticks…heavier than white oak….turns nicely though
BG, it sounds like the wood you have is jatoba (AKA "Brazilian Cherry"; Hymenaea courbaril.) It's a very attractive and strong cabinetwood with good wear resistance. It's often used for high quality flooring and it would make a nice table...if you had enough of it in the kind of dimensions necessary to do the job. If that's not the case, there are all sorts of small projects you could use it on: jewelry boxes, display shelves, a small cupboard or decorative turnings, etc. Another thought might be to marry it up with another, contrasting wood (perhaps maple or white oak?) using the other wood in thicker dimensions as the edging...Then go ahead and make a table of some sort.
Jon,
Thanks, I was hoping you'd see this post. I had not thought of the oak or maple as a contrast...nice idea. I was tinkering with the tought of cherry...mush less contrast..but, ya know, two cherries....actually making a frame of cherry with a rabbit and droping in the SA cherry to create an illusion of a thick top. I did glue up a panel about 1 month ago...seems fairly stable...should I worry about wood expansion?
Stability differentials shouldn't be a problem, BG. Jatoba's average volumetric shrinkage, green to ovendry, is 12.7% and it has a moderately low T/R ratio of 1.88. Our native cherry does have a little lower volumetric shrinkage (11.5%), but it's T/R is actually slightly higher than jatoba's. Jatoba is a more stable wood than either maple or white oak, if you elect to marry it up with either of those two contrasting woods...in fact its volumetric shrinkage is almost identical to that of black walnut.
Jatoba contains a resin (a form of balsam) that allows it to sort of self polish as if it had its own built in varnish. It's brutally hard and sometimes difficult to work, especially if it has curly figure, but it's a beautiful wood.
