Fellow knotheads,
Here is an idea that should stimulate some discussion. Several years ago, my shop occuppied only a small portion of my basement. The lack of space forced me to think creatively and, out of desperation, came up with this cabinet for mounting two stationary tools: the planer and the spindle sander. I chose these two because they are never used in tandem. I have used the cabinet ever since, and have no major complaints.
The two tools are mounted in opposition on a sub frame which also mounts the pivot shafts. I attempted to balance these, but I only got somewhat close. Still, the balance is good enough that I can rotate between the two positions with relative ease. To convert from spindle sander to planer, I pull the stops, rotate the planer to the top and lock it, and then I roll the unit like a wheelbarrow over to a position where I can get a long infeed and outfeed distance. I use the jointer dust collection hose on the planer, so a dedicated dust collector is unnecessary. This conversion takes about 60 seconds. It is easy enough that I am not reluctant to convert back and forth several times a day.
Attached are photos of each operating position, the unit stopped in transition, and a view of the wheels which set just clear of the floor.
Best regards, Tom.
I have seen that idea before -- 2 machines that can be flipped in one stand.
It is a good idea, and yours is nicely designed and well executed.
I would encourage you to email the idea (and pics) around to various wwing mags, since they are always on the prowl for stuff like this. Just about every wwer is looking for more efficient ways to utilize shop floor space.
I would not be at all surprised if you got a bite, since your photos are good, and the stand looks sharp. Did you paint it, o is that melamine?
John Wooden 1910-
Thanks for the kind words. The cabinet is painted mdf. I'd probably use plywood now, but the mdf has held up.
Best regards, Tom.
Hi Tom, that looks nice. How high are the two tool work surfaces when each is in the up position? Seems like quite a difference. I'm guessing the planer is lower than "normal"? I nix the idea of sending to a mag, just forward your plans directly to me :) Kidding of course, sounds like a good idea. Regards
Thanks for the feedback. The spindle sander work surface is 50". The bed of the planar is 31". I chose these for my convenience. You can vary the pivot height and the thickness of the mounting "box" to produce the heights you want, within reason.
Best regards, Tom.
Very clever and well executed! But doesn't the blood/oil/sawdust rush to the head of the tool that's upside down? ;) I second the idea of mailing it in to the magazines--somebody's bound to print it. Tom
