IS THIS THE SAME AS SPAR VARNISH. lOCAL HARWARE STORE TOLD ME IT WAS
Sorry about the caps lock
Not necessarily. I prefer to use McCloskey's Spar Varnish which is based on tung oil. I guess the question really is what are you planning to use it for.
Tim
Soon-to-be furniture maker
Port Townsend, WA
YES,
now, what do you want it for, the reason others and myself ask is that sometimes spar varnish shouldn't be used..
I have a walnut cupboard and the recommend finish was equal parts boiled liseed oil, spar varnish, and turpintine
That mix is my favourite rubbing finish which is durable and easy to maintain. I think that the is no pratical difference between using a tung or urethane based spar varnish in finishing the cupboard.EnjoyTimTim Lawson
Port Townsend, WA
Thanks for the input.
Mark
