I have a chance to get a Grizzly 586 jointer with the spiral cutterhead for several hundred off (local deal, still in crate). I’ve seen some mixed reviews in the magazines about the cut quality.
So is the extra money for the spiral head worth it? It seems like a lot of money for very little benefit given that I will still sand, scrape, or plane before finishing. Even with this deal it is still more than an equivalent jointer with the standard 3 or 4 blade head.
Also, if it came down to equal money for the spiral head vs. the parallelogram tables, which is more important and which would you buy (price being equal as in my opportunity).
Jake
Edited 10/24/2006 8:24 pm ET by ohcomeon
Well worth it.
Best,
John
Jake, this thread should provide some pertinent info.
forestgirl,
I read that thread and was suprised that so many were comparing a carbide helical head to a straight HSS head, and using the durability of the cutter as a deal maker.
I use solid carbide jointer knives and they are amazing. Perfectly smooth for a long, long, time.
Hal
I would never consider it an either or proposition involving parallelogram tables versus insert tooling. I work on a lot of jointers and find the parallelogram excels for four point adjustment of the tables. Also if the table ever warps you can regrind the one table and mount it back on the machine. With dovetailed ways jointers the whole machine must be ground if the table is warped. A slight sag can be shimmed.
As far as the cutterhead, If you do a lot of figured wood it has a clear advantage. The Shelix with it's shearing cut is a bit better but haven't compared it personally. I do have access to a Northtech planer with insert knives similar to what you are looking at and it really is better than straight knives. People get confused on the cost. Carbide lasts 8 times longer and there are 4 edges so the cost overall isn't as bad as it seems. It does leave small lines but one still has to sand the wood.
Edited 10/25/2006 11:40 am ET by RickL
It isn't so much as looking at it as either/or but rather in this case I have an opportunity to get the standard jointer w/ spiral head for a good price. But I had been considering the parallelogram style. Therefore the dillema.
If I get the parallel jointer I can always upgrade to a spiral head later but I can't upgrade to parallel design (unless buying a new jointer). So that is where I'm going with trying to decide whether to jump on this opportunity.
thanks, Jake
Is the parallelogram jointer a better design? Some say it is, so probably.
Is it better in any way that will significantly affect the quality of your woodworking? Not likely.
