I have recently started using Zinsser Bullseye “French Polish”. I have followed all the directions carefully and cannot seem to get a even mirror like surface during the spiriting off stage. Running in the direction of the spiriting motion there are dull streaks typically – everyonce in a while I can get an even shiny surface…maybe once out of ten times. I am using lint cotton jersey material formed into a small pad…nearly saturated with denat. alcohol. – I lightly bring the pad into contact with the surface overlapping slightly with each stroke. I really like the quality of the finish and it’s ease of use…but I really need some help here!!
I have not used the bulls eye product but when using regular shellac and oil the spiriting off pad should not be too wet. Sometimes I add a little shellac and alcohol and work the pad lightly until it starts to dry then a little more pressure as it gets harder with less alcohol until the pad is practically dry and the oil is taken off.
It can be hard to describe with words. I thought the whole idea of the bulls eye product was that all you did was pad it on and the lubricant would eventually evaporate. No need for spiriting or stiffing off.
Anyway, you may just need to use a little less alcohol or add a small amount of the polish to the pad. And also start with a lighter touch.
Lastly make sure the rag covering the pad is tight with no wrinkles.
J.P.
Thanks for advice.
I guess technically it's not spiriting off (because there is no oil)...Zinsser calls it that though. They call for it essentially to "melt down" the slight ridges of shellac from the padding...and create a uniform glossy surface. I am going to try and be a little more aware of how tight the pad is...and use a lighter touch and see how it goes.
Too much alcohol. I think it is a hard part of the process to get right. Don't get discouraged.
Frank
