Cant’ e-mail you because of firewall block.
Expound please....?
Rick, Don't know how to turn that blocker on or off. I just wanted to thank you for your suggestion on ther jojnter AND since I live close by in North Attleboro, MA I jokingly said maybe if I cant get that darn jointer fixed (fence square to both infeed and outfeed sides) you could help me..:-)!!
Got your e-mail but couldn't send a reply back. It's your security settings.
Probably your fence is the culprit. I have no idea what procedure you used to check everything else but you said with the second fence it got worse. You can bend cast iron to some extent. Clamp one end of the fence to a very solid surface and clamp a 4' x 4" x 48" and overbend it a bit and you can probably take the twist out. It does work.
