Everyone,
I have to splice together two pieces of stained/finished crown molding to cover a long run of wall cabinets. I know generally molding is joined mid-span with a scarf joint. But, to my eye, the scarf joint looks more noticeable than two butt cuts placed end to end. Is there any reason to use the scarf other than more gluing surface? (which should not matter with small crown on cabinets).
Thanks.
Frank R.
If the wood shrinks or moves, you can see through a butt joint and not a scarf joint.
If you're really careful, you can make a scarf joint almost invisible. I use a dab of glue and a couple of 23 ga pins to hold it together while the glue dries. A little touch up with a wax filler and it's gone.
Don't get too hung up on that mid-span business. When I have to do a scarf joint, I try to put it in the most inconspicuous place I can. Near a door is often good since people seldom look up when they're walking toward a door. Over a window can sometimes be a good location since people look out windows - not above them. If the window has (will have) a window treatment, that will usually hide a joint as well.
We moved in to a new home about 2 years ago, the guy who did the kitchen used a butt joint in the same situation you described, looks terrible.
FrankR ,
I try and find an area of grain and color that will lend itself to a nice match when spliced with an angled miter , even if it means wasting a bit of molding to get a good looking splice .
good luck dusty
Everyone,
Thanks so much for the input. I have a 23 gauge pin nailer so I'll cut the scarf joint in the least obvious place, pin and glue it. After it dries, I'll put it up.
Thanks again.
Frank R.
Face the long point of the scarf joint away from the side you will see most often.Arlington, Texas (The dash in Dallas-Fort Worth)
Practice...'till you can do it right the first time.
After I posted my last message, I thought about asking which way to cut the joint. Thanks.
FR
