Hello, I’m wandering over here from the Fine Homebuilding Boards.
I have original wood windows (90 years old) which I am currently restoring. I’ve run into something outside of the realm of my previous experience…something that would require the finesse of a woodworker, I think.
The previous owner had put a coat of latex paint on the (inside of the) windows before she sold (gah!) which I am painstakingly stripping off. In the case of one window, A mullion is a bit, well, “splintery” on the surface. Not soft or rotted, just seems to be dry.
Of course, the finish of every other window under the latex is terrific. Original stain is even and, with a new application of shellac, should turn out well. And DH is set on these restored windows to be stained and shellacked versus re-painted.
I’m not sure how I should approach protecting the splintery mullion. Lightly sand it to smooth? Apply wood hardener? But if I do that, will it prevent me from trying to match the stain? I don’t know much about restoration finishes…
Thanks much for any advice.
A couple of questions:
Is wood actually splintering off, or is the finish coming off in slivers?
Is this on a mullion between windows, or an a sash bar or muntin that actually holds the glass? I ask that because of the size difference.
Splintery wood can be glued down with liquid hide glue then wiped down with a wet rag to take any excess glue off the surface, and the repair will take a lot of stains OK.
If it's the clear finish that is failing, it has to come off. Shellac will come off with denatured alcohol or an ATM (acetone, toluene, methanol) stripper, as will lacquer on small jobs.
If that doesn't answer your question I think we need more info. Always test before committing.
Michael R
"You have to look for possibilities where there are none" Krenov
Hi Michael--
Thanks for your response. I do think it's the wood but it isn't deep. And it's only in a small area. I took some photos of the project (and don't worry, we tested for lead paint before we started and the results came back negative.)
The first photo is of taking the last traces of shellac and paint off with denatured alcohol to reveal the stain.
The second is of the pattern of the mullions for a "healthy" window.
The third is the area I'm concerned about. The wood is very dark grey in this spot and brittle on the surface (as you can see from the area where I tested it and broke off a sliver.) I'd also like remove the handles, fill in the holes where the screws were, and replace them (the current holes have become loose over the last 90 years.)
I'm on a break and typing quickly. Sorry about any spelling mistakes. Thanks much!
jmo
Pictures sure help.
The wood is weathered, probably from a combination of UV light and condensation.
If it were mine, I'd just sand it smooth and get on with it.
You could fill the splintered out areas with wood epoxy or wood filler, but unless you are very good at touchup, it will look worse than just smoothing it down.
There are more drastic approaches such as replacing the parts or inlaying wood to replace the old, but you need equipment and experience to do those well.
HTH
Michael R
Thanks! The pattern of the damage definitely indicates that condensation could be the culprit.
I'm going to use the mouse then, and sand it down carefully. Any suggestions for filling those holes from the window handles? Since the handles will be going back on, how it looks under stain wouldn't be as important.
I feel more confident tackling this now. What a help!
I'd hand sand, myself. You can use the edge of an old deck of cards to improvise a contour sanding block.
Two common ways of filling screw holes are to whittle a plug and glue it in, or to fill with wood epoxy. The epoxy comes in rolls where you cut of a slice, knead it thoroughly to mixk and stuff it in the hole. Regular wood filler works, but not as well as the first two.Michael R
Deck of cards, brilliant! Thanks!
Any specific brand on that epoxy by the roll...I don't think I've ever seen that.
No. they are all pretty good. Most hardware stores carry it either in their adhesive or paint departments, adn I think you'll find it in paint stores.
Ask for "Tootsie Roll" epoxy.Michael R
old deck of cards to improvise a contour sanding block..
DANG! Why did I never think of that? AND I thought I was sort of smart..
So simple it hurt....
I certainly applaud your effort in maintaining the original look of your windows (they're really nice windows by the way), but I do suggest you take a look at a more durable finish than shellac. It doesn't stand up that well on windows, as the water condensation and large temperature changes are problems.
Sherwin-Williams makes some high UV resistant finishes that we have been using. You can tint them with TransTint to alter the color if need be. They are a vinyl sealer and an acrylic top coat.
Abatron epoxies cure a bit harder than the tootsie roll ones, but you will have to use a bit of paint (burnt umber is a good starting point) to camouflage them if the are exposed.
