I found an estate sale over the weekend and got some bargains. I bought two Sheffield panel saws, both had some age, but in good condition. Straight plates, just a bit of corrosion. At $10 each, I think I got a bargain.
I noticed one had split nuts. It is stamped C.P. Preston Sheffield, Cast Steel, Warranted. There is no etching on it. And it has a nicer handle – figured wood, more ornate design.
The other one is etched Sheffield Saw Works, Cast Steel, Reliable, No. 59. Indianapolis, Ind, USA
I looked them up on Ebay and the split nut versions seem to be priced higher.
Is the split nut saw special? If so, why?
Generally, older saws have split nuts. Makers started using unspli nuts to save on manufacturing costs.
Older saws had the name stamped on the plate as well. Sawmakers started etching the plates later on.
