Does anyone know of a good splitter for the delta unisaw.
Thanks Lou
Thanks Lou
Hi Lou,
I use the Biesemeyer splitter, it's a bit pricey (about $100). Best feature is it easy to remove and replace when necessary, which means it gets used as much as possible.They make a model that fit's the Unisaw perfectly
Best of Luck
Hey Lou,
I use the Biesmeyer too on my Unisaw. However if you have a Grripper the splitter is to tall to fit under the tunnel. I found this out when a friend loaned me his Grripper. Other than that the Biesmeyer is a great splitter it won't get knocked out of alignment easily, and as mentioned before installs and removes in seconds.
I like the gripp'r. I use the thin kerf forrest blade, and they make a good one that is perfect. I also use the grippr push sticks. They glide right overtop, and my overarm gard fits over top of it. Finally, I like that when doing a dado I can just pop it out and back in. Good luck on the decision.
