i got some cabinets installed a couple months ago and at the side where the boards are joint is opening what is the cause of this and how can this be prevented.
ecoore,
Can you give us a bit more info ?
Are these modular or custom made cabinets ?
Is this where the cabinet side meets the face ?
If it is a face frame cabinet and it is separating at that joint , perhaps not enough glue was used , or it should have been clamped if it was not flat . It's hard to say exactly what's up with out seeing it or having more info .
regards dusty
these were custom made cabinet and it is where the board are joined to make the side panel
Is a heat or ac outlet blowing on that side of the cabinet? Any other source of hot or cold air? Drapes/blinds open and sun beating on that side of the cabinet? Radiator close?
yes it is beside the stove
How can i prevent the cabinets from splitting even though it is beside a heat source.
Use man-made sheet goods for the carcases, narrow stiles and rails, and plenty of room in the grooves for the raised panels to shrink and swell (use SpaceBalls).
ecoore ,
The joint splitting could be from material not being at the correct moisture content , or lack of glue or warpage or swelling possibly caused by say a boiling pot on the stove .
What type of finish is on the cabinets , and look carefully to see if there are any other finished ends or places that this is happening .
dusty
