Help!
Building a kitchen table with white oak. Dimensions are 37″x52″ right now. The top has been sitting for six months. Two of the boards in the top are splitting. Both splits are about 12″ long. Would it be best to cut the table and reglue or inject glue into the splits and clamp it?
Your best bet is to rip the splits out and reglue. Your wood was not properly seasoned and there is no fix for wood that is not properly dried. The wood is shrinking and moisture loss is ten to fifteen times greater out of the end grain, this is the reason the wood is splitting from the ends.
Was your air dried?
Lee
Furniture Carver
Lee-
I've ripped the splits and I'm about to reglue. When the boards are placed together there is about 1/16" gap between the boards, with a total of three pieces to glue together. This doesn't seem like enough to worry about. Would you disagree?Jase--Is there a better way?
Jase- Yes a 1/16 is enough to worry about in only 12 in. I'd imagine the pieces are too big to handle through a jointer, so hit the edges with a jointer or jack plane. It shouldn't take much. Hit it lightly and check often. John E. Nanasy.
Hey guys,
I was able to pass the panels through my jointer. The largest piece is about 20" in width. That took some concentration but I got it without any problems. I haven't check for gapping. Hopefully I will be able to glue it up tonight.
Thanks for everyone's help.Jase--Is there a better way?
As with all defects or mistakes in a woodworking project, an option is to make a feature out of the splits. If it fits with the design of the piece, you could put butterfly inlays along the split to stabilize the check and add an aesthetic aspect to it. However, it all depends on the style and upon your personal taste. What is the base design like? I'd be curious as to how you solve this problem and what the final product looks like.
Tim
