spokeshaves and 50 degree low angle blades
![](https://secure.gravatar.com/avatar/a86f7afd370d9f924f9de66e5c73b093?s=52&d=https%3A%2F%2Fimages.finewoodworking.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
am interested in buying veritas spokeshave .mostly finishing curves on table tops and skirts.will a flat model do or should i get a round one also?question about 50 degree low angle blade. working in alder. are these type 2 chips something an intermediate woodworker should strive for?
If your work involves regular table surfaces with an outward radius, you will be fine with a flat spokeshave and you might find it quite useful for a lot of other things. On the other hand, if you have inward curves present or other hard to reach surfaces go for the curved sole spokeshave. The 50° bevel blade will help you smooth out difficult, cross grained, or easily chipped woods. If you find alder difficult to plane with your regular 25°blade, and the 38° still isn´t working as well, then go for the 50°, just remember that it will require a lot more physical effort to work with it.
Spokeshaves and 50 degree low angle blades
I support the comments Artex has made, with only one addition. I would only add that you want to keep your spokeshave set for a very light cut. Really good sharpness, a very light cut, and you should be very happy with your outcome.
