I would like to try to finish some of my work using a spray finish. Mostly I would use it for laquer, varnish, or solvent based products. I would not want to exclude oil and water based paints.
Most of my work is higher end specialty cabinets & furniture mostly for family and friends so this is strictly for home & workshop use.
I have a 6hp 20gal compressor capable of 8.6cfm @ 40psi. I have been looking at the porter-cable PSH1. It seems to be okay for light use but I’m concerned that PC offers very little in regard to technical specs or basic accessories. I would think that one cap does not apply for all woodworking finishes etc.
Any suggestions for starting out? I don’t want to buy a “cheap” gun, find out I like spraying and then need to move up to a better gun. Money isn’t to much of an issue so I would like to get a good product at a fair price that is designed for a woodworker. Everything I see seems to be made for a production automotive finish.
John
http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=23294.1
this thread had some things to say about spray equipment check it out.
Cup guns ( suction feed) do pretty well with lacquers and oils, not so well on latex paint. I suppose some waterborne finishes are not that thick though. If money isn't really an issue, I'm tickled silly with my Binks pressure pot. If you go that route, get dual regulators, invest in pot liners, get enough hose to walk around with (like at least 25 ft) and here's the downside - expect to start using a lot of solvent when it comes time to clean. If you use it only for lacquer, then use lacquer thinner to clean it out after you flush the lines, and leave clean thinner in the lines until the next use. If you swap out with oil paint, you have the chance of having paint residue in the lines and when the lacquer hits it, you suddenly have paint sputters on your finish. The rare times I put something other than lacquer in it, I'm partial to running a gallon of acetone through afterwards to grenade anything in there out.
Thanks for the quick feedback. I checked the thread and this provides some good advice. As for the pot, I think this may be to large for me. my projects tend to be small and one piece at a time. I think I'm going to opt for gravity feed and a mid size container.
I see the guns falling into two price categories, $100-200 & $300-500. Are there really any performance differences betwen the two? I'm sure the production guns are built to last, but don't they both lay down roughly the same quality finish given the operator uses the same technique?
To give you an idea of what I mean: I just moved from a Dewalt random orbit finishing sander to the Fein sander of the same size. I paid a ton for the Fein but the difference between the two is night and day. I don't mind paying more for a product when there is such a marked improvement in performance and results. I dont sense that spray guns are the same, it appears to me that the more expensive models perform at near the same level. Would you say this is basically true? If so, I would be perfectly happy with one of the lower priced products and can get on with my selection.
I apologize for being so picky about this, I cannot recall having such a difficult time choosing a tool. Maybe it's because the technology is so far removed from actually working the wood that I'm just struggling to understand where the value points are.
Thanks again
John
My first gun was a cheap "Bulldog" import. Nice for splatter painting. I got a Binks #95 for around $300. This is a gun more than good enough to paint cars with. Works great with lacquer, varnish and waterborne poly (stainless steel innerds) but I'd like to switch to a Turbine HVLP system so I can spray waterborne in the shop without all the overspray. Most people I've talked to say the conversion guns are air hogs. I usually look to pay 1/2 price for used stuff so I'll make you the same deal if you're interested. John O'Connell - JKO Handcrafted Woodworking
yeah, oddly enough, I was trying to match "splatter" on some drywall repairs and could not for the life of me get my gun to do it. Turned the pressure way down and still got a very small, nicely atomized stream. I called my sales rep from SW and said "now what?" He opined that my gun was too nice, and suggested going to Bob's El Cheapo Closeout Everything, Inc and getting a $20 cup gun, since it would probably be well adapted to just that. I did, and the splatter job looks perfect. Not your average problem.
