I am looking to purchase a new spray gun. The one I have is about nine years old and its’ okay, but I’m looking to upgade to either a two or three stage HVLP gun or a gun opeated from an air compressor. I’m open to suggestions both pro and con for any type system.
Kimberly
If I were in your shoes, I'd go to http://www.homesteadfinishing.com. The proprietor there is Jeff Jewitt, an excellent finisher, and author of several books and articles published by our host. He sells hvlp and conversion guns, and will be able to steer you in the direction that most suits your needs.
I'd go with an HVLP setup. It's very portable,less overspray, etc.etc. A spray gun connected to a compressor requires tremendous volume(capacity) to run continuously at higher air output.
I actually have both. What you are saying is correct up until a few years ago, but Eco, among others, sells a conversion gun that doesn't need gobs of air. I have a large compressor in the shop, so for myself it doesn't matter. I like the Eco with my compressor more than my 3 stage turbine hvlp. I can crank up the air a little to increase atomization, without thinning the product. Before all the expert finishers jump in here, that ain't me. It's just what I've learned from Jeff Jewitt, and have applied it successfully in my shop. I'm curious to hear back what you think.
A conversion setup sounds good, what is the size and cfm of your compressor?
I have the Ingersoll Rand 80 gallon 5hp motor. Its from their commercial line, as I use it to drive a 3/4" HD impact wrench, etc... 27.4 cfm at 90 psi, a boatload of air. However, the Eco doesn't require anywhere near that, and I believe I read (correct me if I'm wrong) that a 20 gallon smaller Porter Cable type compressor will operate it just fine.
I just wanted the fella to know that there were options out there. I used to love my Apollo hvlp, and guess I still do. But now, with the Eco, I only use the Apollo for paint. The Eco stays dedicated to WB finish.
My Asturo Eco/S runs on 7cfm at 21psi. You can, and I have, run that gun on a pancake compressor.
Kimberly, I think you would really appreciate the ease of using a gun that doesn't have the large volume turbine hose attached to it, I also have an Asturo eco but mine is set up to run
off a 2 quart pressure pot, so I also have a Walcom gravity feed cup gun that I use to spray
shellac and waterborne lacquer. Having only the 3/8" hose to deal with is really a lot less
hassle and I really love the performance of the Walcom gun. Call Jeff at Homestead and you will get all the info you need to make an informed decision.
Ron
the pressure pot setup is the way to go for larger pieces, that will be my next investment.
The pressure pot setup is great if you are standing in one spot and doing a lot of spraying
and also gives you the ability to turn the gun upside down if needed. I bought it while doing
some contract refinishing on 265 courtroom seats. For almost everything that I do in the shop I prefer the cup gun whether the piece is large or small.Ron
I use a gravity feed top gun for almost all of my work, but for "inside work" the lack of maneuverability can be a pain. I also like cup guns for being easier to clean and less waste.
