Hi everyone,
I am getting into some advanced projects and made a kitchen island out of maple which came out great. However, I used Maple and didn’t know that Maple doesn’t take dark stain very well.
I needed the piece to be dark brown so I am using Benjamin Moore oil based paint, called “bittersweet chocolate.” It is a satin finish.
I am using a good brush for oil and high density foam roller.
I now want a little more shine than the satin and want to know if I can spray polyurethane on top of the paint?
I don’t have spray equipment so will use the spray cans.
Also, I am not sure why some spots have less shine than others…is it because it is a dark color? If I spray on the poly will it even it out?
Greg
With Satin paint it is very important to thoroughly mix (several full minutes) before using and to continually re-mix while applying. Satin finishes contain a silica flatting agent which must be kept evenly in suspension.
I do have a question or two. Did you use a primer? At least two coats of paint? It's possible that, without primer and/or multiple coats, you are experiencing areas of different porosity in the wood that have let some areas soak in to a greater extent, leaving the surface less shiny. If this is the problem, it's not entirely certain that the addition of the very thin rattle can finish will give an even sheen.
Have you considered applying another coat of paint--this time in the semi-gloss sheen. By the way, if semi-gloss is too shiny, you can split the difference by mixing satin and semi-gloss. Paint is as tough a finish as the spray clear coat would be, though the aesthetics are different.
You will want to evenly scuff sand the surface before applying another top coat. Inspect carefully with lots of light, and use your fingers to feel for defects. Working toward perfection in the penultimate coat can go a long way to assuring that the final coat gives the desired results.
hi Steve,
Thanks for writing back, I didn't have a chance to check back for replies until now.
Actually since I posted I sanded and added a third coat and things are much more even. actually I think my issue was I am using a foam roller and I have to roll it in the same direction. I think I was just seeing a different sheen from not rolling evenly.
Also, you are right I need better light! The most room I had is in my basement and the time I have to paint is afterwork at nite so I did my third coat holding a work light in my other hand and that helped.
Greg
hi Steve,
Greg
