I have been using brushed SW ProClassic for cainets and interior trim and really like the way it flows and levels.
I have recently purchased a CAPSpray 8100 3 stage turbine outfit. The product sheet for ProClassic gives a tip size for:
Spray—Airless Pressure …. 2000 psi, Tip (fine finish) .010″-.014″.
Is there a simple conversion to a HVLP gun tip/projector set equivalent. My CAPSpray unit has three projector sets (0.31, 0.51 and 0.70).
Any thoughts?
SW would likely have given an HVLP tip if they thought it desirable. That said I am sure some folks do successfully spray enamel. Since you already have multiple tips, I'd suggest making your own tests.
...making your own tests
Steve - thanks.
I hate to paint. I hate to clean gunst up. I was hoping to reduce the "testing" to a best guess equivalent. Oh, welllllllllll!
