Hi,
I’m a hobbiest who enjoys painting furniture. Two years ago, I purchased a HVLP/ 4 stage turbine system because I wanted to start spraying my projects. I use latex acrylic paints, which has it’s challenges, but also fits my conditions. I have been able to get some nice results, although my current project of trying to spray a black sem-gloss is torturing me. No matter what, I can’t get rid of the subtle orange peel. Anyway, to get back on track, my main purpose is ask if anyone knows of a website or info source that deals with this area of interest. Again, I’m referring to “Spraying water-base paints and finishes with an HVLP/ turbine set-up on furniture. Thanks for any suggestions.
Kalena
Check with the HVLP manufacturer, or whomever you purchased the kit from. They want you to be successful.
http://www.accuspray.net/trouble%20shooting.htm
Orange peel
Orange peel can be caused by several factors. First, make sure you are the proper distance from the substrate being painted (6 to 8 inches). Orange peel can also be reduced by thinning your material further, using a smaller air cap, or adjusting your pressure up to compensate for material flow.
http://www.homesteadfinishing.com/
http://www.woodweb.com/
Or, try
http://www.google.com/search?num=30&hl=en&lr=&safe=off&rls=GGLD%2CGGLD%3A2004-44%2CGGLD%3Aen&q=orange+peel+hvlp&btnG=Search
Thanks for the suggestions. I've tried different needle sizes, but I've always changed the nozzle with the needle. Probably because I've always ordered them as a set. Guess I never thought "out of the box" on that one. I'm familiar with the Homesteading and Woodweb sites. I like the Homesteading one a lot.
Kalena
Ooops. I'm am amateur and just learning to use HVLP, but what that short blurb was talking about was changing the Air Cap. The needle and nozzle are a matched set, and (as I understand it) must be the same size. But you can change the air cap which has a size number. The air cap is the outer part that on many sets has the air horns that shape the spray pattern. Part #29 is the aircap in the parts breakdown on the page at http://www.accuspray.net/10_gun_breakdown.htm
So, you use the needle/nozzle set for the product, and can also change the size of the aircap to help in atomization and pattern. You might also talk to the help desk at the paint manufacturer. They also want you to be successful.
Thanks for clearing that up. I found out that no matter what adjustments I made (either to the gun or paint), I couldn't get really nice results spraying the BM Regal Aquaglo. It's a rich paint with a lot of body. So I switched to a BM water-base enamel, called "363". The paint was expensive, but worth it. I'm finally getting a very smooth low lustre finish, and my project is moving forward.
Thanks, Kalena
It is the Wagner 2900 Softspray HVLP System, which includes a 4 stage turbine.
Karen S.
