I haven’t done a lot of these but the ones I have, as the panel shrinks it reveals that ridge of the finish where the panel met the rails and stiles. I would really appreciate it if someone could explain what the steps would be to prevent this. If I pre finish the panel, how do I then put the finish on the rails and stiles, do I cover the panel? I’d like to do more of these but this issue is holding me back. Thanks for your help.
Are you using paint or clear finish? Either way prefinishing the panels is the best option and then using care not to apply too heavy a finish coat that it pools in the joint. Commercial furniture and cabinet manufacturers even the premium brands use MDF center panels on their painted cabinets for that very reason.
I use catalyzed lacquers or CV. If I don't cover the panel, when I go to spray the rails/stiles wouldn't I get way too much build on the panel? Thanks for the help.
If you are worried about it you can just do a light perimeter spray of the panel. The idea being when it shrinks it won't expose bare wood. I can't think of anyway to effectively cover the center panel that would not cause as many problems as it solves not to mention the time involved. Just apply the lightest coat you can is what I do and have not had any problems.
Spray them NOW. Where I am it is winter heating season and everything wooden is about as dry and small as it will ever get. If you can't spray only in winter, I'm on board with Esch for the prefinish of the edges.
