Does anyone knows where can I find square dowels 1/4″ , 3/8″ , 1/2″ x 36″ hardwood to buy in small quantities of a 100 pieces each size
square dowels?
why don't you just make some on your tablesaw?
Seems like the easiest solution to me.
JD
Make them yourself? At quantities of 100? Whew. That's a bit of work, not to mention how much material loss would be due to saw kerf, planing, etc. Considering time and money, buying them would be a no-brainer, IMHO.
Scott
Hobby store or dollhouse shop. Building model airplanes and dollhouses are what comes to mind that would require that size stock (although 1/2" might be on the large side there). Your choice is likely to be basswood, balsa or basswood.
HTH
Graeme
Oh, you said "hardwood". Guess that eliminates the balsa, doesn't it? :-)
Edited 5/13/2003 1:58:17 PM ET by GEESEAWHY
I'm with JDorn on this one. Heck, you can make 100 square dowels in minutes. I'd bet if you did the calculus it's less expensive.
It's also a good way to use scraps.
I only buy the round ones.
-Ken
Oops, my bad. Just looked at your profile and saw that this is your first thread on this forum. You may not have the tools, etc.
Yea, your best bet may be a hobby shop. You might want to see if there's a local woodworking group. What's your locality?
-Ken
Pilon,
Making your own is simple and quick. I made a large quantity of square dowels from Ebony the other morning, to the exact dimensions I needed. It was liberating because I wasn't limited to the sizes available in a store or catalog, there were no shipping charges, and I didn't have to wait for UPS to deliver.
As others have mentioned, this is a great use for offcuts - just make sure your blank is wide enough to keep your fingers away from the blade and prevent the stock from rolling over.
If you want two-inch dowels, and you start with a blank four feet long, you'll get all the dowels you need ripping only three or four pieces from the edge of the blank.
(1) Square a blank, (2) plane to the appropriate thickness, (3) rip a few lengths from the edge, (4) smooth the cut edge with a plane or scraper, and (4) crosscut to length.
If you joint the edge of the blank before you rip each strip, you can reduce the hand- planing, although I found it quick, easy, and pleasant to plane the cut edges smooth.
Waste and planing are minimal if you use a multi-tooth, thin-kerf tablesaw blade or a bandsaw.
Adjust the cut-off-stop on the fence of your SCMS, and cut them all to exact length in just a few minutes. If this feels too dangerous, crosscut them at the bandsaw.
Good luck with your project,
Paul
