HI, I’m popawheelie’s daughter, and I’m designing a set of four cutting boards for my mom for Christmas. I was looking for some suggestions on foodsafe dyes for the stain. What I am planning to do is make matching inverted sets of two, with contrasting light brown middles and teal blue sides, or vice versa, creating a two-color, three-stripes effect. I also am not sure what wood would be most suitable. My dad suggested maple or sugarpine, though sugarpine would be to soft. I need something that is pretty cost effective and readily available. Any suggestions would be appreciated.
Thanks. RF
I think maple is a good choice. I suggest you contact Jeff Jewitt at Homestead Finishing (http://www.homesteadfinishing.com/ - telephone and email contact info is listed at the web site). They sell dyes that should be suitable for your project, and Jeff can tell you which ones are food-safe.
I agree on the maple. It seems to be the cutting board standard. Thanks for the tip on dyes! I found a set of analine, foodsafe dyes that I'm gonna use. They came pretty cheap too, only about $20.
Thanks, RF
ALL finishes are foodsafe once they're cured.
I didn't say anything about food-safe finishes; I was talking about food-safe dyes. If one were to apply a water-soluble dye, and then use the cutting board after having applied only a non-curing finish (e.g., mineral oil), or no finish at all, then there is a good chance that the dye will leach into whatever it is that you're cutting.
Dyes would have to fall in the same category as finishes. Any cured finish sold in the US must be non-toxic once cured. That would have to include any dyes, stains, or colorants.
"Any cured finish sold in the US must be non-toxic once cured. That would have to include any dyes, stains, or colorants."
I'm sorry, but that's simply not applicable. There are thousands of pigments and dyes available that are not certified for food contact, and only a handful that are. See 21 CFR 178.3297 for those that are certified (in the US). Would you use this on a cutting board?
You are not correct about all finishes and not all stain pigment/dye are safe when in contact with food. I'm not going into an argument or details about this, if anyone wants to know, they need to do some research.
Hi RF ,
How about food dye /colorings ?
Apply a mixture of Mineral oil and paraffin wax melted together over the dyed surface , apply generously .
Alder is nice also for a cutting board
good luck dusty
How about food dye /colorings ?Glad you posted this. When I read the original post it was the first thing that entered my mind. I was not going to post it because most folks think I'm a nut anyway and besides I have never tried it. I think I just may do it and see what happens.
Hey, by now we think you're a nut no matter what you post....
Food dyes work fine to color the wood, but they're frequently not very lightfast, and can fade pretty quickly. There just aren't that many foods where you need the color to survive a few years...fruitcake, maybe.
Hey Will ,
If it didn't come out right you could always eat it ,,, what do I know , I'm just a wood worker .
Apparently , according to some the food coloring is not a good way to go .
dusty
Have you thought about making "serving trays" instead of "cutting boards? Cutting boards need to be made from hardwoods (like maple) and finished with something non-toxic (like mineral oil). They have to stand up under some pretty heavy use, and need periodic refinishing.
Serving trays, however, can be made from almost anything since they're more decorative than functional. Most of them get used to serve crackers or cheeses at parties.
