I have constructed some cabinets from red oak plywood and red oak facing and have stained them, but no top coat yet. They turned out too light. What are my options for making them darker but wood grain still showing? Glazing? Never done this before!
What type of stain and application?
Dave
Later
AspenDave http://www.aspengroveltd.on.ca
minwax oilbased - wiped on
How long did you let it penetrate, and what sanding grit did you finish with?Later
I let it set for several minutes until it seemed to match some other furniture I have. Not very scientific, huh. I have not done any sanding yet. As you probably have figured out, I am an amature at this!
Thanks.
If I understand you correctly, you did not prep sand the product before you applied the stain. If this is the case you probably have a good amount of uneven colour as well as being to light. Sanding not only evens out the surface, it also removes "mill glaze' and allows the stain to penetrate properly. I would try and apply another coat of stain and brush it in very well and let it set for the full time (15 mins), but do not let it dry, then wipe it off. But since the prep work was not done properly, you will probably have to glaze and tone the product.
Hope this helps.Later
You are correct in your assessment. I probably didn't sand enough first. But you have confirmed my thinking. Thanks for your help.
As AspenDave stated, glazing or toner is probably the only way to match another piece of furniture, if that's what you are trying to do. I would suggest practicing on some scrap before committing to one or the other.
