Stain turned out nothing like the sample
did you stir the stain in the can Really well? Often the pigment settles to the bottom of the can? Did you also apply a topcoat? Stain can look very different with a topcoat applied.
Agree with mrossk. Also, have you used this stain before and had it be the right color?
Sanding should not be a factor. Also, if it is oil based, temperature would not be a factor except for drying time. It is possible that the red in the oak is coming thru the stain; a second coat might help.
This is an example of why everyone should do a sample finish before using it on a real piece.
About 20 years ago I was trying to find a "cherry" stain to stain some pine windows that were getting trimmed out with cherry. I tried at least 4 different brands, the first three having no noticeable similarity to the color of actual cherry wood. The last one tried was Minwax cherry, which did a pretty good job, tho it was hard to get the depth of color in cherry even with a similar color.
I try not to stain oak and other dense woods, preferring to use a dye (TransTint) mixed in alcohol. Here also the color can be significantly different before and after the topcoat.
Changing reds is difficult and red oak bleeds. I can't tell you how many times I have seen people in an attempt to white wash/ stain their 70s -80s red oak cabinets or paneling for a more contemporary look only to end up with pink! A pigmented shellac could possibly be a solution. Or pigmented over clear. I have done that in a grey tone over redwood ( another bleeder) pretty successfully. As was stated above always do a test before proceeding pretty much with any finishing your going to do. It's pretty common to find a pretty surprisingly different or disappointing result from what you intended working with finishes. I find myself fussing around with the chemistry sometimes for hours trying to get the result I want. Rarely am I happy with what comes straight out of the can.
