What is the appropriate way to address end grain on plinth blocks that will be stained?
It seem unavoidable to have exposed end grain on ornate plinth blocks – what are the best practices here?
Sand. Sand. Sand. Then use a sealer on the end grain. That should minimize darkening, but you will never be able to completely eliminate it.
Sand the end grain at least 2 grits (3 if you can stand it) beyond the rest. I don't do much staining. I'm a wipe on oil (Osmo or tung oil) kind of guy. But the idea is the same. End grain soaks up finish faster than long grain. You want to slow the absorption of stain into the end grain so you can get it wiped off before it wicks in too deep.
As a strategy, stain the end grain first. Then make time adjustments on the long grain to get the best match. As always, practice on scrap to find the right combo of grit, seal and timing.
There is usually very little end grain showing, particularly on very ornate plinth. There was usually a mounding on top covering most of the end grain. But if yours is exposed, a wash coat or two of finish, as above, will keep the end grain from soaking up as much stain. But make sure you do test pieces first.
In the past when using Minwax stain on end grain I have cut with 50% mineral spirits. Turned out great. As mentioned above, experiment with some wood scraps.
