Hello! I have purchased a variety of Cherry Wood which will be used to construct a large piece of furniture consisting of bookshelves, cabinets, a computer cabinet, draws. All of the face fronts are solid cherry – select grade. We wood like to stain the Cherry a medium color – darker than natural but light enough to appreciate the grain. I am looking for some advice and recommendations with regard to staining the Cherry. I have never stained furniture before (what a project to learn on). I have read a lot about staining Cherry – and frankly I am confused and concerned. There appears to be a problem with blotching when staining Cherry. Polyurethane v lacquer – gel/tinting – what are the best materials for Cherry? Someone has recommended I use the Deft products – stain and clear coat. Do you have experience with staining Cherry? I wood appreciate some guidance and recommendations. I have a lot invested and would hate to be disappointed with the finish.
Thank you in advance for assistance.
Do a search of this forum looking for "Old Masters Cherry Penetrating Stain".
PlaneWood by Mike_in_Katy
PlaneWood
Thanks Mike I will conduct the search.
If you're investing a significant amount of time and money (which it definitely sounds like you are!), I'd suggest you pick up a copy of Jeff Jewitt's book Great Wood Finishes" ISBN 1-56158-288-3. He details 3 methods for finishing cherry and provies color plates for illustration. This is an excellent book, and the section on cherry alone is worth the price.
When researching how to finish Alder, I was following the threads on cherry since the two woods subject us to similar challenges with regard to finishing. Determined that anything I make with either of these woods will require lots of testing and practicing on scraps before taking the big leap on the workpiece.
Thanks for the feedback. I will pick up the book today.
Cherry happens to be one of my favorite woods, but I never use stain. I put a coat of dewaxed 2# cut of garnett shellac and about 3 or 4 coats of wipe on varnish. From there I let nature take care of the rest, cherry will darken on its own with in a year or so continuing to darken for at least a couple of years.
Scott T.
Hello,
I read your message to md concerning staining cherry and I have a question.
Are the coats of wipe on varnish intended to change the color of the cherry or for the toughness of the film.
Gene
Edited 1/27/2003 10:10:14 AM ET by Gene
For me it is just the protection it provides, shellac is not a finish for a piece that may see adult drinks, it also will show water rings from glass that may be set on it. I use the garnett shellac for the small amount of color that it gives the cherry.
Scott T.
Thanks for the answer.
Gene
Forest Girl said it best: Practice on test pieces. Take each piece throught the entire finishing process. Every step of sanding, sealing, staining, etc. whichever approach you take.
I'm about to embark on a major cabinet fabrication project in a few months. I'm in the same boat you are - I want to use cherry for parts of the project. I intend to try out a number of finishes as I've described to see how they turn out. After a few disasters of the first order what with finishing various woods without such testing, I've learned ... the hard way .... you need to explore if you aren't familiar with the terrain in order to arrive at your destination.
Dennis in Bellevue WA
woodnut@anatechsys.com
Dennis, that is good advice. I am going to finish the wood before building the unit - so I am anxious to get it finished. Testing different finishes will be time well spent.
I never stain cherry, rather I sit it in the sun for awhile after it's scraped or sanded to finish. I use high gloss varnish mixed with a small amount of thinner. Wipe on-wipe off . . . three times at least. Then when dry buff with a brown paper sack. It turns out better than anything I've tried including all the spraying stuff. High gloss is important because it doesn't hide the grain like satin etc. does.
http://www.finewood-n-things.com
md - I also like cherry a lot and have experimented with a variety of finishes. There are some stains that do an excellent job on cherry - very even coloring, no blotching, the grain is nicely enhanced, and the wood still has a "shimmering" effect when rotated in the light (especially the light and medium colors). Other coloring techniques that produce nice results include dying the wood, and applying a colored finish (called a toner) over a coat of clear finish.
I'm not familiar with the stains from Deft, so I don't know how well they might work on cherry. Deft makes a lacquer that I've used, and I can say that lacquer is a very nice finish on any wood - cherry included.
I've collected some samples of different finishes I've tried and put them together at this link - http://www.boomspeed.com/firstfinish/CherryFinishes01a.htm . The link may load slowly because of the pictures. If you want to use one of these finishes, I'll give you the steps to do it.
Paul
F'burg, VA
Paul,
Just wanted to express my appreciation for the beautiful job you did in preparing this web resource and making it available to the sawdust crowd. The photos are wonderful, as is the presentation. Can't wait for other wood samples!
Bert
md, Scott's response is correct. I have seen some folks try to rush cherry to its natural tan with a brown stain/dye but in my opinion it is best to let the wood take its natural course. This is one wood that will not disappoint you!
