Hello,
I have an oak stair tread that I stained to match the other 5 stair treads. I sanded the stair tread at 150, then 220 I believe. It was very smooth and clean. I applied the stain, let it dry and it looked really nice. I brought it upstairs to lay it against the other 5 treads to see how close the stain matched. Very close but a little lite. So I decided to apply a 2nd coat. 2nd coat goes on, I waited about 15 minutes before I wiped it off. Everything goes fine and then I notice what looks like a water splashed stain – right in the middle of the stair tread. I have no idea what it could be. It showed up as soon as I began wiping off the stain. Again it is right in the middle of the stair tread and it was not there before the 2nd coat went on.
So, can I sand the stair tread down at that point as best I can and reapply stain to that spot – or will that just begin a pattern of mismatched blotches on the stair tread – if you know what I mean?
thanks
alexsunny
Can only speculate but is there any chance any type of sealer was spilled on the wood? Did you possibly wipe it with a rag that could have been contaminated with something? Was anyone else in your shop that could have had an accident and not mentioned it(considering all possibilities especially if you have children)? Posting some pics could be helpful.
