I am using throughout my house a 10 inch baseboard. I have a stair with 6 inch steps. I would like to know how to determine the correct height for the baseboard surrounding the stair? At what point do I start to climb from the bottom baseboard and where do I end at the landing? I also have a problem on how to transition from the end of the stair into a turn on the landing. How to transition with the baseboard from the stair to the landing and turn to the stair again. Perhaps I can not explain myself clear. I am attaching pictures.
Hi Amaury:
We're mostly furniture makers here so baseboard is not exactly our expertise. However, I have done my fair share of home improvement projects that involved installing baseboard so I can tell you how I tackled this.
The technique I followed, which is pretty standard, is to use a 10 in. to 12 in. wide board for the stair baseboard and cut it into a "reverse stringer." Basically, you will cut the inverse of your stair rise and run into the board so that the top edge of the baseboard is a straight line. That probably doesn't make much sense so I attached a crude line drawing and embedded it below.View Image
It comes out so that the stair baseboard ranges from 10 in. wide (or 12-in. wide) to just a few inches wide where the baseboard is positioned over the corner of the stair.
Write back and let me know if I'm answering your question clearly.
Matt Berger
Fine Woodworking
Edited 7/12/2007 4:16 pm ET by MBerger
