I have made a few humidors in the past but would now like to build a larger one that is more like a piece of furniture. I have seen a few that will hold about several hundred cigars. They have been almost like a cabinet, with multiple drawers, and a blower at the bottom to circulate the humidity. Does anyone have any idea where I might find such a plan? If not, any ideas about plans I might be able to adapt to design one?
All thoughts and comments are welcome!
Theodore
Sorry guy I couldn't help myself:
Theodore's Humidor!!
Duke
Did you see the one on the back cover of FWW #170? An amazing piece of work.
"... Buy the best and only cry once.........
LOL - I hadn't made that rhyme yet.
I will check it out. I am trying to take a pic of my friend's to post so that folks can see what I am talking about.
Thanks.
I just jumped in here -- have you found any info yet? In '99 I designed and built a cherry chest humidor which has held 1200 if this interest you --let me know --right now I 'm looking for some ideas on how to engineer a bank of cedar lockers (100 ) probably split up into units of 25 each with a humidifier for each 25 == over the past 10 or so years I've probably made 259 or rerular humidors making sawdust Vernonmaking sawdust
thanks for the reply. that sounds like something I would be interested in. Do you want to connect offline or can you post? again - thanks sooo much!!!
finnally getting back to you-- just finishing putting a bid on a 25 locker unit for cigars fun--fun --fun you know I have some good pictures of the 1000 size humidor but theye are all 35 mm when my daughter comes over I see if she can scan a pix to you --- I know what you are up against -- no available info on such an animal why don't you wait to see if I can at least show you some shots of mine ( which is now out in Dallas TX ) I am in Tampa FL the last time I talked to the owner he has had as many as 1200 in it and it worked just fine talk to you later making sawdust Vernonmaking sawdust
Anything you've got would be great. After I take a look, maybe we can discuss the plans you used (or invented). Thanks again!
