Just bought a 90 listed on eBay. Anyone care to post copy of their instructions or direct me to a site that has them?
Did they come with instructions? Make sure the blade is SHARP. Slide the bullnose forword ro back to open or close the mouth depending on how rank a cut you are taking. Make sure the blade is sharp, and the edge is square to the blade since there is little lateral adjustment. You can remove the bullnose part entirely to use it as a chisel plane. But be sure the blade is sharp.
Thanks for the description Steve, will apply advice on sharpening soon.
Kevin,
The #90 does not come with instructions, at least at present.
and www.flairwoodwork.spaces.live.com)
Thanks, enjoyed looking at your work. I agree with your philosophy of combining machine and hand tools with the 90 as one of my first hand tool purchases.
Kevin,
I bought a new #93 years ago-I still have the box- they don't come with instructions, promotion leaflets of other models etc as far as I know. I can't see what instructions would be needed, for example the blade can only fit one way.
Have you got a problem with the way it works or a sharpening problem?
No problems, just wanted to be thorough starting up. I appreciate the reply.
