I have recently acquired a nice Stanley Bailey No. 3 hand plane . However, I am suspicious of the depth adjusting nut. Most that I have seen are of solid brass. This one has a bright metal core and a black plastic exterior. Can anyone tell me if this is a substitute? It looks fine and works very smoothly. If it is the wrong one, I will look for an original and replace it.
It might be a "type 17" (1942-45) war production with a hard rubber adjusting knob. It depends on the rest of its characteristics.
One shop teacher to another. Thanks for the info. The knob probably is hard rubber from closer inspection. Thanks again.
I have several No 3s, I love the size for fine work
small frame and panel assemblies, thin edges, smoothing areas of complex figure ect.
A plus in your case is the War era Stanlys typically have heavier castings, I guess
as some sort of bonus for not using brass?? as most of the brass was used for the war effort.
Clean er up and put er to work !!
Didn't have to clean it up. All I had to do was to sharpen it and tighten the tote screw a little. It really handles nicely. I have one with brass but it is not in nearly as good condition and I paid $20 more for it.
Congratulations on your new plane.
If you want more information on Stanley planes than you ever thought existed, and haven't been here yet, try this site:
http://www.supertool.com/StanleyBG/stan0a.html
Cheers!
James
