Good Morning All !!!
I am building a round table and the skirt I am covering the outside with 1/16 X 4 mahogany. I was planing on gluing it the mahogany to the frame with Hyde glue. I was going to use a veneer hammer, and I was wondering if I would have a hard time with holding the veneer in place with the Hyde glue.
I had a though that just maybe I should use a steam box to bend the radius of the skirt.
I would be very thankful for any help I can get, as I have never done any veneering before, and for that matter I have never done any bending with steam before, nor do I know how to make a steam box. So I need all the help I can get.
Thanks to all. Jack
Jack, there will be lots of info on the internet about steam boxes, and bending too. We have some great veneer experts here at Knots, sounds like a fun project. Here are a couple of links on steam boxes:
http://www.woodworkweb.com/woodwork/contentid-4.html (a wooden box)
http://www.woodworking.com/article.cfm?article=1219 (Michael Dresdner on making a pipe-type box)
Thanks Forestgirl, where did you get a name like that!!!
Jack
Greetings Jack ,
How big around is your table top to be ?
With 1/16" thickness Veneer edge , unless the circle is a very tight radius no steaming should be needed .
You will need to use Masking tape or something to hold things where you want them when gluing .
regards dusty
steaming shouldn't be needed unless the radius is pretty tight. And Mahogany doesn't steam well anyways. If bending is a problem bent laminating or hot pipe would probably work out better.
Hello Ted Thanks for your reply, The table has a radius of 17"
Jack
Sparky, you definitely don't want to steam a 1/16" x 4" piece of wood. It will just curl badly across the width. One you have the piece made, I'd curl it up in a circle, loosely at first, then tighten it up, gradually, over a week or so. You may be able to fit it in a large bucket or pot, temporarily. It should wrap around a 34" table with out any trouble if the grain isn't too heavily figured. This is an application where the use of contact cement might be the easiest. Use a short nap roller to apply a coat on both the veneer and the table edge. Allow it to flash off/dry but not too long, 20-30 minutes is about right. Contact cement works by applying pressure, you can use your veneer hammer or borrow Ma's rolling pin.
I have a picture of my el cheapo steam box. The most important thing is lots of steam, that means plenty of water. I use old electric tea pots to pre-boil the water I have to add to the big can. This keeps the steam production from being interrupted.
