What;s the benefit of using the steel cups for rare earth magnets? I was planning to just glue the magnets into holes drilled with forstner bits. Should i use the cups?
As I recall, the cups have a countersunk screw hole, allowing the whole thing to be removed, if needed. There may be some "magnification" of the magnetic field, as well. Simply gluing the button into the wood should work, too - assuming there isn't too much seasonal movement. But, you're talking about a small section of wood, so I don't think there is too much to fret about in that regard.
If you screw the cup to the wood you will not remove the cup once the magnet is inserted.
cup or no cup
I agree, as advertised, putting metal behind a rare earth magnet incresses it's magnification. Other than that, the washers just make it easier to reverse and recover the magnet.
The metal cups are a very good idea, If the rare earth magnets set slightly below the surface in the cup. Rare earth magnets are some what brittle and I have had them break if two of them slam directly together.
In my experience with rare earth magnets it seems the cup adds to the magnet's strength.
Yes, it is easier to install and it can be easily removed. However there have been times the piece the magnet is holding takes the magnet with it, out of the cup, when pulled away.
So, the magnet is not held into the cup by any mechanical means?
mechanical attachment
"So, the magnet is not held into the cup by any mechanical means?"
Nope. Not needed.
5 min epoxy works without cups, and the disks are easier to remove this way. Removing them from the cups requires breaking them into bits / dust by drilling them out, if you haven't filed a lip for a screwdriver on them first.
Pre-drilled & countersunk ring magnets:
https://www.kjmagnetics.com/products.asp?cat=15
Personal preference, but I think cupped magnets just look better.
