I am trying to find steel pins – I think they are also called steel dowel pins – which will be used to hold a piece of wood in place to slide up and down. One end of the pic will sit halfway into the wood. The pins are round and steel and about 1.5 in length – I cannot find them at my local hardware store – where are they easily located?
http://www.mscdirect.com
McMaster-Carr very likely has them, too, but I don't know their URL right off the top of my head.
Also try a local machine shop - they're a pretty standard item. They are hardened and ground to exacting tolerances and may be overkill for what you are doing. If you can't find them locally, you might just be able to get away with buying steel, brass or aluminum rod & cutting it with a hacksaw.
If you need a bunch of them, the cheapest way to go is to buy a 36" drill rod from an industrial supply house and slice off as needed, using an abrasive cutting disc on the TS.
what about using 5 mm shelf pins? They are cheap, round, about 30mm long, with a tapered end
Tom, Taper pins are what you want They come in all diferent lenghts and thicknesses.
They are designed to fit tapered holes which require a tapered reamer to ream out the hole.
You'll like the convenience of tight fit but easy removal they intail
They beat nuts and bolts when making jigs and fixtures that MUST retain tight and accurate placement. If you prefer, a cheaper route would be 'Rollpins' They are hollow tubes that will expand a little and are driven in with a drive punch of the matching size. Steinmetz
Thank you for the suggestions. I am working on building the router table featured several issues ago and the plans call for steel dowel pins to hold the horizontal sliding table in place. I'l check out these options. Thanks - Tom
What magazine and issue is the article? I'd like to check it out.
http://www.mcmaster.com sells all kinds of great supplies. I order from them several times a week. Typically get the order next with regular UPS.
