Because I’m stuck in this &%$@$%ing wheelchair for now, I’ve been trying–and failing–to come up with a good design for a cabinet to hold my CDs and the equipment to play them. There are some design limitations:
Because of my apparently permanently dimmed eyesight, I want to be able to see the front of the CDs, so I don’t have to try to read the miniscule writing on their edges. This, of course, means drawers.
For the same reason (eyes) and because of my back woes, I need the CD drawers to be on top of whatever shape this beast takes.
I need about 12′ of linear drawer room for all my current CDs and for those yet to come. So if, e.g., all the drawers are 12″ deep I would need 12 drawers. The face of a CD case is about 5″x6″.
My four components are all about 18″ wide and 5″ high. To accommodate all the wires and such, I plan on making the part that holds the components 18″ deep.
The problem is that with all those drawers up top, I cannot seem to think of a way to design such a thing so it doesn’t look terribly top heavy. I’m trying to avoid making a chest on chest kind of design, with doors covering the drawers and the component shelves–but I’m willing to listen to reason.
HELP! Can anyone think of a solution? Or has anyone seen a good design for such a thing? Please.
TIA
Alan
I can't think of a complete solution right off the bat. Here are a few thoughts which come to mind.
Can the CD's be layed in drawers like spices in a spice rack drawer? In other words, the CD's, rather than being layed flat, are tilted up at an angle, say, 30°, with the one behind tucked underneath a little bit. They lay on a zig-zag sort of rack. You would not be able to see the complete front, but most of it, and that may be enough to recognize them.
Another idea might be a drawer where you flip through CD's stacked front to back, much like they are arranged in stores.
Maybe something other than a cabinet. How about a circular rack which spins like a lasy susan. It could contain frames which would hold say 9 or 12 CD's and flip like pages in a book, like the display racks where you flip through posters in a poster store.
If bright lighting helps, you may be able to incorporate it into the design or nearby.
I believe they also make CD changers which hold near 100 CD's. But, I don't know what they cost, nor whether any come with a display which is clearly readable.
There may be associations and other web sites which can put you in contact with people more familiar with design requirements for special situations.
Actually, they make them to hold as many as 400 CD's/DVD's, any mix. Crutchfield carrys them: http://www.crutchfield.com/ Here is quoted text from the online catalogue description.
"The Sony DVP-CX985V is a terrific multi-purpose addition to any A/V system. It combines top-notch progressive-scan DVD picture quality with the ability to store and organize an entire collection of DVDs and music discs — up to 400 discs total! In addition to regular CDs, the DVP-CX985V plays both stereo and multichannel SACDs (Super Audio CDs) — a new disc format that reproduces music with greater realism. Sony's Disc Explorerâ„¢ displays a list of every loaded disc on your TV screen, and lets you access discs either alphabetically by title or by slot number."
This is the way to for keeping your DVD's and CD's organized.
Lee in Cave Junction, Oregon;
Gateway to the Oregon Caves
Alan
I think Wayne has the way of it, a CD stacker/changer or two or three !
The only thing I'd add is take the inserts out of the CD cases and place in an album in the same order that the disks are in the changer or any other order so long as you know what position in which changer the Stones "Black & Blue" is stored.
Ian
Building on what said, you might consider removing both the CDs and the liner notes from the plastic jewel cases and putting them into CD albums. Once you get rid of all the plastic jewel cases, it is amazing how many CDs can be stored in a small space, and be accessed more easily. If you go this route, and alphabetize them, remember to leave some open slots, so adding new disks does not require a comeplete re-alphabetization.
My CD collection is approaching the 500 mark. Your right, thats a lot of space. I would never consider getting rid of the jewel cases because some are always being moved around to the different places they are used. I rotate 10 to 12 to work, 6 to 8 to the family/wifes car and 3 places in the house (diningroom/kitchen, den and son's room). I store around 340 on two black walnut wall shelves/cases (multi-shelves). The CD's sit on the shelves like books (vertical). I'll guess the sizes, one at 9 1/2 wide x 4 shelves and the second 16 1/2 wide x 6 shelves. I organized them on the dining room table before filling the shelves. And right, leave blank spaces.
Enough background, back on topic. I think 12 drawers would be a real pain. Maybe 3 or 4 larger drawers with 3 or 4 rows of CD's per drawer.
I thought about the multichangers a few times. The newer models have a USB interface to the computer. They come in a bunch of capacities but they are slow to change disks, a pain to fill up and hard to get back at a certain disk for transport. IMHO
Turn up the tunes!
Enjoy, Roy
Roy, and all others,
For many reasons ,right now a "fix" of my design problem won't include acquisition of another piece of audio equipment.
I've thought about using fewer drawers. If I used one 18" or 24" wide drawer per tier, the cabinet would likely look less top-heavy. But I'm worried that when one wide drawer is pulled out, the shift of weight might cause the cabinet to tip. I've seen what can happen when the weight of CDs isn't taken into consideration.
Thanks again to all. I guess I'll keep trying different arrangements of the necessary elements of the cabinet.
Alan
i would look into more of a side board or credenza design rather than a verical cabinet you could lower the center of gravity and the effect of one drawer being pulled out. this is what i did and i like how it turned out. i used pull out shelves with cd flippers that you can buy from rockler in the side doors and equipment in the middle doors.
