Hi All,
What shou;d I use to sticker fresh cut wood? I know this is a wide open question and would like to keep it that way. Is there any commonly accepted material that I can use to sticker any wood that won’t adversely affect it,?
Hi All,
Rob,
I use 1x4's or 1x6's #2 Common White pine. White Pine won't stain the woods I am trying to dry and it is reletively cheap. I just get some boards and rip them to 3/4" width and 4' long. Since they are already 3/4" thick they make quick stickers. I get a little less waste if by using 1x6's instead of 1x4's.
Good Luck
Michael Burton
Thunderbird Hardwoods
KD Mesquite
Llano, TX
I use 1 x 2 firring strips. Buy em at the HD or Lowes in a bundle and cut em in half. easy reusable and consistant thickness.
Andy
"It seemed like a good idea at the time"
Rob
You know all those thin strips left you rip off your stock that are leftover. Voilla. Make sure they are dry, and planed to the same thickness. DO NOT use red oak. I found out the hard way on hard maple about 12 years ago. The acid in oak turns the new stock black. I ruined about 300 bf of beautiful maple. Expensive boo boo.
Same species is good, so is poplar.
Almost any DRY white wood is good, about 1 -1.5" wide. It is better to have an absorbent soft wood rather than have the moisture captured by a dense wood.
