I want to make a box with through dovetails and a groove in which to fix the box’s bottom. I want to make the groove using my plough plane, but I am unsure how to make a stopped groove so that it doesn’t show on the bottom pins. Do I simply use a chisel to mark the end of the groove and plane to that mark? Any advice would be greatly appreciated.
instead of a groove to hold the bottom, just use your router to rabbet the bottom edge of the drawer and then use a chisel to clean up the edges.
If you are dead set on a groove just plow a dado in the drawer sides and after you glue it up you can fill in the voids by gluing in some plugs made out of scrap. You will not even notice the plugs.
Wyldewood,
I'm about to do the same thing except I'll use the router table; no plough plane. Before the router however, I'll make some mini-mortices and then drop the stock over the router cutter. Hopefully someone has a better solution.
I suppose you can drill or chisel a stop at the end of the grove. What plane are you using 45?Ron
Ron,
Yes, what your calling a stop, I'm calling a mini-mortise(1/4x1/4x1"L). I do not have a plane..I'll use the router for the rest of the grove.
Thanks Ron and BG. Chiseling a stop (or mini-mortise) is the way to go, I think. I appreciate the advice.
I've done a lot of dovetailed jewelry boxes that are just as you described. You sound set on using the plow plane and power to you. Chiseling a stop will work just fine. My two cents:
Consider the width of your groove when laying out your pins and tails. The groove will have to extend into the tails and run out between the two lowest pins (this runout will be covered by the tails) follow me? So leave adequate room for it.
gotcha. thanks.
