I was hoping someone out there could advise me on storing some hickory I plan on using to make some kitchen cabinets. I bought it rough sawn, kiln dried and have had it for 2 years or more. Meaning to use it promptly I stacked it without stickers. promptly never happened- you know how that goes. Anyway it seems fine and I am in the process of thickness planing some of it and hope to get at my cabinets by late winter here in Wisconsin, but may get delayed again. Do I need to sticker the planed lumber or simply stack it? And does the answer depend on when I actually may get the cabinets finished as the humidity in Wis. goes from desert conditions in winter to very humid in summer? I store it in part of my workshop that is kept at abut 45 degrees in winter and open windowed in summer. thanks in advance,
Always sticker your stock before and during the milling process. You need the air to be able to circulate freely around all the surfaces. You may "get away" without doing it but why take the chance for two minutes of work.
I always position it so that air can reach all sides. If the temperature and/or humidty in the shop will change between the time you milled it and the time you use it, you must do this.
You've already received the good advice to sticker.
Here's another thing to keep in mind. If you expect a long delay between planing the wood and building the cabinets, don't plane to final thickness. Leave a little bit on, in case it moves a little more. Do the final planing shortly before construction.
Thanks- I am planing down to 7/8 for now . Partly because on some of the more figured pieces I was getting some tearout. I was hoping to get a new Performax sander for Xmas to take the last 1/8 off and avoid that problem and ol Santa really came thru.
After I have my lumber stickered, I always put some weight on top. I use cement blocks.
3 on each end of a 4' wide stack of lumber and 3 in the center. Be sure the weight
is above the stickers.Ken
Working with Hickory. This is some hard stuff. It can be done but you need to minimize your milling work by stacking it with stickers at all times. After hickory dries, it is the hardest wood on tools that I have used. Only teak will tear a saw blade or planer knife up quicker. Bottom line: Do what ever you can to minimize your tooling. Good Luck.
thanks for your insight
