What is the best or perferred way of storing lumber? Horzontinal or Vertical? I really don’t have much room in my shop to store wood…I could keep it outside in a shed, but am afraid it will ruin the wood…any ideas or comments would be appreciated.
My preference is to sticker and store wood horizontally on a flat surface. If stored vertically with a bend over time the curve might set in the wood.
It might be safe to store the wood outside if not exposed to any rain or snow, and stickered flat. The drawback is that the moisture content likely will be too high to make furniture until the wood is brought inside for several months. A moisture meter would be useful to confirm when the wood brought in has a moisture content of about 7%.
storing wood
Thank You..that's what I thought...I was hoping for a vertical way, but that way is just not correct...
vertical stacking it fine
If you want to save space and be able to get to each unit without moving your pile around, vertical stacking is the way to go. Each board just needs to be constrained by the ends and middle with stickers. Once the wood is dry the restraints are not so much needed. Note there is a difference between vertical stacking at leaning against a wall. Each unit should be plum to avoid bending over time.
I prefer the third option of storing it on edge. Best of all worlds with the benifit of every board being easily acessable.
Rich
Adam is correct - if vertically stored wood is without a bend, it's fine. You could cut some plywood triangles fastened on edge to the wall, so that boards could be perhaps 10 degrees off vertical (so they'll stay standing) but be fully supported straight.
